It is currently Fri Aug 08, 2025 3:55 am
 Post subject: 1/8" sides?!
PostPosted: Tue Jan 16, 2018 1:20 am
I was working on some nasty upper bout back/side damage from someone's girlfriend, and I noticed the sides were 1/8 inch thick!
It's an Epiphone Masterbilt solid Rosewood. It is a dreadnought. I would not have thought that you could Bend that thick. Has anyone else seen or tried this?
 Post subject: Re: 1/8
PostPosted: Tue Jan 16, 2018 2:02 am
Last Name: Kincheloe
I saw some pre-bent cocobolo classical sides on ebay one time that were 1/8" thick. The oils in rosewood seem to really help with bending.
Black walnut is another of the easiest to bend. 1/8" would be no problem with it. Probably could even do OM type shapes (assuming straight grain/not too much runout).
Ebony, on the other hand, hates to bend even at 1/16".
These users thanked the author DennisK for the post: Pmaj7 (Wed Jan 24, 2018 11:19 pm)
PostPosted: Tue Jan 16, 2018 5:25 am
I know a builder who many of us know although he's not a member on this forum he bends at .150" which is a bit thicker than 1/8". He uses a Fox style bender too to do this. Go figure. He mostly bends EIRW and Hog.
These users thanked the author Hesh for the post: Pmaj7 (Wed Jan 24, 2018 11:19 pm)
PostPosted: Tue Jan 16, 2018 8:38 am
Last Name: Cox
I do most of my sides at > 0.125".
These users thanked the author truckjohn for the post (total 2): Pmaj7 (Wed Jan 24, 2018 11:19 pm) • Hesh (Tue Jan 16, 2018 9:22 am)
PostPosted: Tue Jan 16, 2018 10:26 am
My max is about .1in on a hot pipe. That's hard enough to bend. I could probably swing 1/8th on some of the easier to bend woods but then, why?
PostPosted: Tue Jan 16, 2018 10:54 am
" I could probably swing 1/8th on some of the easier to bend woods but then, why?"
On a shape with relatively flat sections and no tight bends (dreadnought) it might improve stability with out causing problems with bending.
These users thanked the author Clay S. for the post: Pmaj7 (Wed Jan 24, 2018 11:25 pm)
PostPosted: Tue Jan 16, 2018 1:49 pm
First name: Mark
Last Name: McLean
City: Sydney
State: New South Wales
Zip/Postal Code: 2145
An eighth of an inch is nothin'......!
I just steam bent some wood for a table leg that was 20mm thick.
Boat builders and furniture makers often bend wood which is an inch or more thick, and into some pretty extreme bends. If you are interested, take a look at these couple of videos.
https://www.youtube.com/watch?v=zKn8sMJ5RxA
https://www.youtube.com/watch?v=--iPQIwSEJM
These users thanked the author Mark Mc for the post: Pmaj7 (Wed Jan 24, 2018 11:25 pm)
PostPosted: Wed Jan 17, 2018 9:29 pm
Last Name: Minch
City: Chestertown
Zip/Postal Code: 21620
I have worked on 2 tall ships during construction. One has a 96 foot hull and the planking is 2-1/4" thick Jatoba. At the bow, there is an almost 80° bend over about 12 feet of planking for about 5 planks on a side. Took 3 hours in the steambox, a dozen shipwrights, and a passel of specialized clamps to get them in place. They are still there 21 years later. Amazing to be a part of.
Ed
These users thanked the author Ruby50 for the post: Pmaj7 (Wed Jan 24, 2018 11:25 pm)
PostPosted: Wed Jan 24, 2018 8:15 pm
Last Name: Howell
City: Atlanta
State: Ga
I tried bending 1/8" walnut, cherry and hard maple bindings, with success, just to see what would work. Not difficult on my hot pipe.
These users thanked the author BobHowell for the post: Pmaj7 (Wed Jan 24, 2018 11:15 pm)
 Post subject: Re: 1/8" sides?!
PostPosted: Fri Jan 26, 2018 8:25 am
Wow, that is surprising so many have done it. Guess I've just never tried it. Seems like those going for the stiffness of double sides could just do this instead. Although, probably not quite as stiff and definitely not a split resistant but way less work.
PostPosted: Fri Jan 26, 2018 5:48 pm
Last Name: Sollod
" nasty upper bout back/side damage from someone's girlfriend"
eek Man, that sounds like your worst nightmare. Don't p*ss off your girlfriend... beehive ;)
www.swiftcreekguitars.com
These users thanked the author sdsollod for the post: Pmaj7 (Thu Feb 01, 2018 11:14 pm)
